FX Loop DeepBlue Delay mod?
Started by George, March 23, 2016, 06:57:11 PM
George
Is it possible to make an Effect loop in Deep Blue delay?
What i want to do is to have an output only for the repeats, connect this to modulation (Chorus for example) and then send it back to the pedal.
jtaormina
Check out the schematic for the newest current lover. It has a send return loop. Maybe this will give you some ideas?
miha
Or try checking out the JMK modular delay, it has a send/return at the mix pot  (center pin) and that's where I put it on the Hamlet delay, I'm pretty sure the DBB isn't that much different :)
George
Thanks a lot for your replies, i ll check it right now :)
Quote from: miha on March 23, 2016, 11:33:17 PM
I can't find it quickly, but Timbo did a quick little write up about adding a send and return using the mix pot like miha said. I know hes done this on a few delays hes built. Search around, im sure its around.
