Pork Barrel
Started by joesatch, February 23, 2016, 03:53:49 PM
joesatch
Finished my Pork Barrel. Everything's working as it should and i biased it. Using, the MN3007 BBD. It seems the effect isn't very prominent (wet). With the depth maxed it makes a subtle chorus effect. Was wondering if this is expected?
daleykd
While I haven't built the Pork Barrel myself (it's on my list), the BOSS CE-2 (to me) was not subtle.  Quite wet, in my opinion.
joesatch
i'll have to try and make a video. The chorus is there it's just not as thick as i was expecting.
I have one on my board and its very wet sounding. You might have an issue with yours.
darrenw6000
did you sus out your pork barrel problem. I just built mine and to me it dont seem to sound as lush as i was expecting, the bias trim pot is on max, im not getting any bad noise or anything.
Orbis_Ignis
mine sounds great and gets very wet and chorusy.
JC103
Just stating the obvious... did you use the correct clock and set the jumpers to corresponding positions for the 3007? Also, are you running it at 9v or 12v?
