Multiple LED's
Started by Roctopus, July 08, 2011, 06:25:17 PM
Roctopus
I'm working on an idea that would require me to have three external LED's. However most builds only have one LED. Is there a way to wire more than one LED to a build? If so, how would you do it?
Thanks!
Can you clarify how you plan to run the leds.  In series on one switch?
Roctopus
Quote from: gtr2 on July 08, 2011, 06:46:30 PM
Yes. I want to put them in clear shaft pots and illuminate three clear knobs at the same time.
k.rock!
I would think running them in parallel might be best... like this:
+9V---- ---|>|---- -------ground
This will supply even voltages to all three of them :)
-Kaleb
God bless!
www.kalebromero.com
oldhousescott
Sorry Kaleb, but no. Whichever LED has the lowest forward voltage drop (even with LEDs of the same type) will get all the current. Put them in series, nose-to-tail. Figure a total voltage drop of about 6v for the three LEDs and calculate your dropping resistor from that.
You could put individual dropping resistors for each LED, but that would mean two more parts and extra wasted energy in the form of heat from the resistors.
k.rock!
Quote from: oldhousescott on July 08, 2011, 08:39:18 PM
Ah! Thanks for clearing it up!  :-[Sorry about that Rocktopus haha
It's always cool to have people like you around to teach us new things :) Thanks oldhousescott!
-Kaleb
God bless!
www.kalebromero.com
Yup, I found this out the hard way once...   :D
bigmufffuzzwizz
Great example of this taken to an extreme!!!  :)
http://www.madbeanpedals.com/forum/index.php?topic=1512.0
I was surprised the first time I realized its as easy as connecting them in series..
JeffdaMaori
... may I add that those are indeed all connected in parrallel though... sorry to spread confusion....
[attachment deleted by admin]
JeffdaMaori
... and science says that bumble bees can't fly by all principles of aerodynamics I was told...
