Washers for reducing pot shaft height to accommodate smaller knobs
Started by benlanc, February 21, 2016, 09:19:16 PM
benlanc
Fuzzdog used to sell some washers that were great for slipping over pots before you mount them in the enclosure to reduce the shaft height so you can have smaller knobs that sit closer to the enclosure. I can't remember for the life of me what size they were, and based on the dimensions I've measured from the single washer I have left (13.7mm outer diameter, 7.4mm inner diameter, 1.5mm thick), I can't find anything that matches.
Does anyone have any pointers for where I might buy some in the UK, and what the proper size is?
I typically use the metal washers on the stomp switch. This leaves me with a ton on the white nylon washers. I've found that if you put those on the pot before you mount it in the enclosure it will get you close to the same height as the smooth shaft pots.
