Nameless
Started by alanp, January 19, 2016, 03:56:37 AM
Aristatertotle
Quote from: alanp on January 29, 2016, 05:33:46 PM
I've got an idea in my head of doing a multi box -- Lovetone flanger, phaser, overdrive, and trem, Madbean reverb, and maybe the DI board at the end for the XLR out.
Wuht.  :o
Quote from: lincolnic on January 23, 2016, 04:17:07 AM
Quote from: juansolo on January 22, 2016, 07:26:31 PM
Symmetrical board stacking!  :o No human would stack boards this way!
8)
Listen -- do you smell something?
;D
Aristatertotle
For doing something like adding back in the effects loop, so you think going with something like the 1590x for the 2" side walls would give enough room for the extra jacks?
Hrm... don't recall the 1590X specs offhand. But look up the 1790NS specs -- nearly ALL of the vertical room is being used for the PCB sandwich and pots.
The 1590X has just about the same specs as the 1790NS except it is deeper
1790NS: 5.625 x 4.625 x 1.5625
1590X: 5.8 x 4.8 x 2.1
Aristatertotle
What I was thinking is maybe with the extra depth the jacks could be double stacked to add the expression pedals and effects loop were one so inclined. Personally I'll probably build mine as you designed it, but my brother in law might have me build one and he wants the world.
