SIP Socket Garbage
Started by playpunk, February 08, 2016, 06:54:03 PM
playpunk
Hello guys:
I put together one of Jon's projects - the most recent fuzz - and I am having problems with it. I think, though, that my problems come from the garbage SIP sockets I got in my most recent Tayda order.
Has anyone else had problems with these sockets? I've used SIP sockets in the past for transistors and other components I wanted to swap in and out, but these ones don't seem very sturdy.
"my legend grows" - playpunk
mremic01
I've never had a problem with them and I've used them quite a bit. One of the things I do that's a little different is that I never solder in just one socket for each lead. I'll snap off a whole row to span the space between the leads so the whole thing is sturdier. If there are no traces under the socket, I'll drill extra holes for the in-between pins to sit. If that's not possible, I'll cut those pins off and grind them down, but leave the plastic connecting both outer pins.
For some components, the leads can be too thick to stick in the sockets. For others (Tayda resistors) the leads can be too thin to stay put. That's more an issue with the socketed components than the sockets themselves.
Quote from: mremic01 on February 08, 2016, 07:43:08 PM
Me, too. I cut the "middle" pins out. So for a resistor, I snap four pins of SIP and then clip the middle two.
playpunk
Sorry I wasn't more specific - the issues are with the components staying in the socket.
Tayda transistors and resistors. I think I'm just going to pull the sockets and solder in the components. Too much hassle otherwise - stuff coming loose, etc.
Quote from: playpunk on February 08, 2016, 09:30:51 PM
could also be thinner legs on the components.
EBRAddict
I've never had Tayda 1/4W resistors seat firmly into SIP sockets. I mic'd five or six brands including some cheapies from ChinaBay and a dirt cheap kit from Amazon and Tayda's were 0.2mm less in diameter than any of them.
I use their SIP sockets & usually pick up a dozen strips whenever I order. I usually spray them out with brake parts cleaner to get rid of any oil before I use them.
It's varied for me.  Some of the Tayda ones have been OK, others have ended up in the bin.
It can also happen if you overstretch the socket, even with the good ones.  Those are really designed for IC legs, not component leads.
There's you problem. At least the resistors, anyway. Those things have super-thin leads that aren't wide enough to stay in the sockets.
jtaormina
I've seen the thickness of cheap resistors leads not fit in those sockets very well.
chromesphere
Yeah, this is the reason I don't like thin lead resistors.  Breadboarding, socketing etc, they don't make a clean connection.
For breadboarding good luck even getting the leads inserted into the board.
playpunk
I'm going to pull the sockets and solder the components to the board. I guess I'll just live with not knowing if the fuzzstainer is better with GE transistors.
Thanks for your help - I thought I was going crazy or forgot how to solder or something.
I bought some DIP8 machine pin sockets from tayda one time. Never again. After one insertion, the sockets were sprung. They would hold a chip, but not in a way that felt anywhere near as solid as the mill max ones I'm used to. I'm sure their SIP are of the same quality. I bet if you replaced them with good ones you'd have no problems.
