DPDT question
Started by mrclean77, February 02, 2016, 01:10:03 AM
mrclean77
Will this switch fit the Tusk daughter board and/or the Opto board from 1776???
http://www.bitcheslovemyswitches.com/#!/Low-Profile-DPDT-Footswitch-Latched-Solder-Lugs/p/51019434/category=5027572
Never messed w pcb pin/pcb mount DPDTs and can tell you the other BLMS ones don't fit...oopsy
I think i found the correct ones at Mouser for double the moolah
TIA
I'm not sure about the Tusk board but i know it doesn't fit in the 1776 board. It does however fit in the Lumen board from GCFX nicely tho!
mrclean77
I do have a Tusk and those switches, I could check it when I get home today.
