Simple Questions About Zero Point Mini LED
Started by steveyraff, May 19, 2015, 12:06:47 PM
steveyraff
Hi guys,
A little confused here. On the BOM it says D2 is a 3mm LED for a rate indicator. It doesn't list any other LED's. However, I see on the board there is also a solder point for another LED. Is this the ON/OFF indicator - meaning there are in fact two LED's visible on this pedal?
If the other is an ON/OFF indicator, I am not sure how to wire that up, as there is only one terminal for it on the PCB. Not sure how that works with the standard offboard wiring guide?
Also, is it ok to use any kind of LED's or do they have to be red diffused like stated on the project?
Cheers!
D2 is the Rate indicator like you said. The LED pad on the board is for your indicator LED. Simply wire that to the positive side of your off-board LED and the neg side of the LED to your 3PDT. In either case use whatever style LED you like.
steveyraff
Quote from: madbean on May 19, 2015, 12:40:35 PM
Thanks man! By the way, brilliant speedy shipping all the way to Ireland :)
Cheers.
