Any fabbed PCB for sans amp bass driver?
Started by the3secondrule, January 11, 2015, 09:56:39 AM
brejna
Quote from: Donleo on May 03, 2015, 08:28:03 PM
Hi Brane! I bought a pcb from you of this effect, yet I'm having a hard time trouble shooting it. Is there a build report online, with voltage measurements?
-donleo
I didn't do any build reports. I'll measure voltages on mine pcb and post them here. What kind of problem do you have?
Donleo
General lack of volume, signal goes through weakly, have to max out the amp to hear it
brejna
Does this happen when blend is in max position and min also? Could you post few pictures of both sides of pcb?
Donleo
Has to be maxed out to hear it, it's silent at any other position. I'll take some pics
brejna
Donleo
brejna
OK, I see the problem... If you want it to work properly you wire it like it is build docs. This is buffered pedal, so input and output are input and output jacks, not effect in and out. Also don't forget to ground jacks. There are three bypass pads, when 1 and 2 are connected pedal is bypassed and when 2 and 3 pedal is engaged.
brejna
Donleo
Thanks Brane! I'll give it a go again!
-donleo
Donleo
I got it going! I'm quite happy with it, it makes my bass sing! Thanks!!!
-donleo
brejna
Quote from: Donleo on May 05, 2015, 06:36:16 PM
-donleo
Awesome! I am glad you sort it out :)
