Super cool build help
Started by jimilee, April 12, 2015, 06:25:53 PM
So I'm building another 4 in 1 effect and I have a question. Using the switcher diagram, I am putting an order switcher between effect 1 and 2 and an rider switcher between 3 and 4. I want to put an order switcher between effect 2 and 3 also. This is what I'm trying to wrap my head around. ANy help would be amazing, every time I think I got it, I confuse myself.
the way I see it, do the following:
* pedal Input and output jacks go to the input of the 2-3 switcher.
* send of the 2-3 switcher go to the other 2 switcher boards inputs
* return of 2-3 switcher from the other 2 switch boards
* 1-2/3-4 boards are hooked up regularly to the effects
this way the middle switch should regulate which one of the others is first in line.
hope that makes sense
Hey thank you, I was over thinking it. When you said wire the in and out in the second switcher board the light went off.
