First build frustration-Zeropoint Double Delay no effect
Started by Crimson_Sky, March 31, 2015, 01:28:59 PM
Crimson_Sky
Bypass mode works fine, when switched on the led works but I get no effect.
I know the soldering looks sketchy at some places but I already reflowed every joint AND scratched between the tracks with an exacto knife (yeah every single one).
Voltages with pots at 12 ' clock:
Pt2399 voltages in Volts
1:4.94
2:2.46
3:0
4:0
5:2.7
6:2.45
7:0.45 on the one close to the pots, 0.34 on the other
8:0.9
Right side :all pins are at Vref=2.46
Tl072
1:4.47   8:8.84
2:4.03   7:4.46
3:4.44   6:4.46
4:0         5:4.44
Bc550
C:2.25
B:0.69
E:0.11
These readings look completely normal so where should I focus?
I will build a probe tomorrow to test the signal path but I'm not sure I'm up to the task.
Can I use the rg keen probe with a tube amp or will that damage the amp?
Audio probe and see if your signal is (a) making it to pin16 of the PT2399 and (b) where it gets lost after that.
Luke51411
Just to clarify, are you getting no effect or no signal when switched on?
Crimson_Sky
Quote from: Luke51411 on March 31, 2015, 01:56:21 PM
No effect. Signal goes through unchanged(I can't hear any difference anyway)
Crimson_Sky
 I should mention input is grounded with the pedal off, when it is switched on neither input nor output are grounded and there is no short between them.
Just checked +9V , +5V, Vb and Ground rails and there is no broken connection.
Also checked 3pdt switch on continuity mode, works fine.
There is a page on geofex regarding getting little to no effect however it's broken  :(
Wonder what it said..
Seriously, audio probe. There are instructions in the Tech Help Rules thread.
Jebus
Quote from: Crimson_Sky on March 31, 2015, 02:28:49 PM
I had similar problem with Zero Point Micro II. Turns out the PT2399 was broken.
