Aion Equinox (No Clean)
Started by Donleo, April 02, 2015, 05:21:42 PM
Donleo
Hi! I just finished a Aion Equinox (M Guv'nah) It sounds awesome when engaged, but there is no clean signal at all. I followed the build wiring diagram to a t. Any thoughts as to why there's no clean signal?
Thanks,
-donleo
By 'clean signal' do you mean a signal coming through when the pedal is bypassed?
If so, then it should be an easy problem to track down - a wrong wiring connection on the switch or a bad switch. If one of the switch lugs got overheated during soldering, it could have broken the internal connection inside the switch.
Donleo
Found it! I spoke too soon. The wiring was switched. It works great now...Thanks Jubal81 for the quick response!!!
