Hacking Delay Tap Tempo Mode? Momentary switch auto connect/release?
Started by brand0nized, March 24, 2015, 05:11:10 AM
brand0nized
[Posted this over at FSB before the forum was back online, but I like this place much better!]
Looking to hack a Behringer EM600's Tap Tempo mode. Stock, you have to hold the footswitch down for 2 seconds to enter tap tempo mode.
Here's what I'm after:
How can I make the momentary switch automatically connect for 2 seconds every time power is supplied to the pedal and then automatically release after the 2 seconds, leaving the pedal in tap tempo mode every time power is applied to the pedal? What sort of options do I have?
I am rehousing this delay with a mixer circuit, therefore the onboard momentary switch will no longer be needed for the bypass function, as the delay will always be on running at 100% wet.
