Red Sonja (engl preamp circuit via amz/jok3rx)
Started by wgc, April 17, 2015, 03:53:23 AM
studiodunn
Very sexy indeed. I love the board mounted switch in the A boxes. Anyone know who sells circuits on those, Non-smd of coarse ;)
Thanks so much guys, floored with the kind words.
Quote from: HamSandwich on April 17, 2015, 02:44:46 PM
So dope. Where do you get your PCB's fab'd?
This one was dirtypcbs.com. Not pristine like osh park but very very good.
Quote from: TGP39 on April 17, 2015, 04:14:48 PM
Absolutely speechless. This is where us non-smd guys miss out. Billy, can you recommend a proper solder station/reflow oven to get started?  I have to try.
Steve.
I use a regular iron that I've had for 15 years. Nothing special. You can YouTube the skillet method, but you can only do 1 side that way. There's a bit of a zen thing that happens, where you guide the part but let it do what it needs to. All about the surface tension of the molten solder.
I see people making gizmos to hold parts in place but it's little like spitting into the wind.  I promise I will post a video soon, finally have the means to do so.
Quote from: m-Kresol on April 17, 2015, 06:58:21 AM
Looks like you could have squeezed another circuit in there. Love the graphics.
Maybe!  ;) on my bucket list. Thank you for the nice comment.
TGP39
[/quote]
Thank you Billy, I will be looking forward to that.
Steve.
that is really neat work, inside and out!  cool pedal!
Willybomb
QuoteI had a bunch of trouble getting it biased properly, still not quite there but close
Not "I had trouble with all the SMD soldering",
Not "Fitting it into a 1590a was a bitch",
Not "I had to refinish the enclosure because the clearcoat crazed".....
But "I couldn't get it to bias".
**** me.  That's maybe one step above "I burnt my finger on the soldering iron".
I think I burned my fingers doing the biasing.  :'(
Used fixed resistors if it's any consolation.
Quote from: studiodunn on April 17, 2015, 07:47:07 PM
I haven't seen anyone else doing this aside from the 3pdt boards people use. It has an element of risk if you solder the switch in before testing and end up with a dud pcb but for me I like all the wiring it avoids.
