Madbean Eagle parts not lining up
Started by waynewalt, March 05, 2015, 03:31:34 AM
waynewalt
For some reason, the 16mm pots are not lining up with the rest of my schematic. Same thing with the film caps in the Madbean library. Looked online, no solution. Any suggestions?
Thanks!
electrosonic
Switch to the "i" tool or just press "i" in the command line.
Click on the pot on question and inspect its coordinates.
You can manually edit its coordinates to be a multilple of 0.1
ie if its x coordinate is 0.2125 for example, change it to 0.2
Do this for the y coordinate too.
You have then manually moved the pot back to the regular grid and it should line up
With everything else.
If not inspect the other elements and make sure they are on the grid.
Andrew.
Try changing the grid from .1 to .05.
Quote from: jubal81 on March 05, 2015, 03:45:21 AM
First thing I thought of also, done that a few times.
