pork barrel clock question
Started by luks999, February 28, 2015, 01:33:46 PM
luks999
is it possible to use a mn3207 with a mn3101 for the prk barrel?
ordered the wrong ic
Yes... but honestly it's not worth the hassle, sure if you ask in the parts jar someone will have a V3102 or BL3102 spare.
But if you're set on it, if you search I helped someone do this before I recall.
luks999
so that means, yes - but i have to change the circuit?
hmm i better go and order a MN3102 then....
thanks
