RingModulators, what are you guy using?
Started by GrindCustoms, January 16, 2015, 05:22:54 PM
Quote from: GrindCustoms on January 17, 2015, 08:15:23 PM
Quote from: alanp on January 16, 2015, 10:59:10 PM
Quote from: Govmnt_Lacky on January 16, 2015, 05:56:26 PM
Ring Stinger FTW!!!
Good project, this. Biased git that I am.
You have a PCB for that? ;D
Yes there are two.
One the string ringer which is a modified layout, and one by gov lacky that follows the love tone original faithfully. The difference is you either have to etch, it get haberdasher to fab the board for you,
It's a tiny bit more effort on your part but you will end up with one of the best ring modulators ever made,
The reliance on pre tabbed double sided pcbs is somewhat depressing...
drolo
I use an EHX Ring Thing.
It can do the ring mod thing but also much more. Pitch shifting (whammy if you use an external expression pedal), tremolo, chorus, a vibey phaser and loads of weird sounds.
For some reason it does not seem to have ever been very popular when it came out and you can find them sometimes quite cheap on ebay.
Really worth a try if you can snatch one
Muadzin
+1 on the Ring Thing. Even more awesome with the 8 step sequencer.
drolo
