Dirtbaby 2n7 caps
Started by Droogie, January 18, 2015, 08:28:57 PM
Droogie
Hi folks—since 2n7 isn't the most common value, could I get away with 3n3 or 2n2? It's the only thing standing in the way of more delay! Thanks!
You'd change the filtering cut offs quite a bit (by about 700hZ higher or lower) so it wont have quite the intended tone.
It'll work though sure, 3n3 will be darker, 2n2 will be brighter.
Droogie
Thanks for the replies! I guess I'll have to be patient.
Quote from: selfdestroyer on January 18, 2015, 09:00:51 PM
These are the ones I used.
http://www.mouser.com/Search/ProductDetail.aspx?R=FK24C0G1H272Jvirtualkey52130000virtualkey810-FK24C0G1H272J
And thanks for the tip—I'll pick up some of those!
