Delay idea, need input
Started by Luke51411, January 10, 2015, 09:29:26 PM
Luke51411
So I just ordered the ZPDD and the ZP Micro and my thought is to put them in the same box and be able to use them as separate delays and to have an option to have triple delay because why not right? I'm planning on putting the zpm first. My thought is to have a splitter blend to have dry signal in parallel with the effect then leave R4 off so there is no dry coming from the Zpm. Then I send the output to the ZPDD which I think would have R4 on a switch for dry kill to extend the delay or in the circuit for 2 separate back to back delays. Does this make sense? Is there anything I'm missing? Would this even be worth it?
TGP39
If you build it, they will come. ;)
Luke51411
Ok so the way I've described it should work then?
blearyeyes
Not sure what you're trying to accomplish but have two clocks running at different speeds might be a bit unruly.
