3p-4t rotary switch
Started by copachino, December 18, 2014, 07:55:05 PM
copachino
hi all, i have never used a rotar switch so im a bit confused on how to wire it i want to switch 4 capacitos and 4 diodes on a neutrino but i cant find the right way to wire it, i see the poles are numbered by 1-12 and have some middle lugs named A-B-C so i guess there are 4 lugs per letter maybe A output have pins 1-4 to be switched, and B 5-8, and C 9-12..
am i right??
Set your multimeter to continuity.
Put the switch anywhere.
Check which lugs are connected to which other lugs.
Alternatively ... find the datasheet for the switch you bought.
Although I can't think of any rotary switches that would work differently from the way anyone could jump in here and describe, these are the things you should do to verify for yourself.
copachino
Quote from: midwayfair on December 18, 2014, 09:19:08 PM
yeah noob question but i made a multimeter test and yep it was working as i describe it before, as it should be thanks
