Hardbinger one more volume.
Started by rosettastoned, December 18, 2014, 12:41:08 PM
rosettastoned
hi guys, I just finish with this proyect, everything works fine, but i'd like to add some more volume to this unit, as I said It works great but at maximun volume.
any resistor to increase the output in al mode?.
thanks
Cortexturizer
I know it because I had the problem of too much volume :) I think that if you change that 3k3 resistor in the preamp section to a higher value, you will get more boost out of it.
Also I am presuming more distortion. Now that's something I noticed I would rather have less of. My own troubleshooting topic about that is underway...
You should be able to make some volume adjustments by altering the values of R11, R12 and R13. Leave R14 at 220k. I would try halving each of those to increase the total output of the effect. Socket first, though....it may take experimentation.
rosettastoned
thanks guys for your quick answere, I'll spend evening working on both solution.
Brian whan you say "altering the values" you mean increase o decrease those values.
regards.
Cortexturizer
Quote from: rosettastoned on December 18, 2014, 01:37:39 PM
regards.
http://prntscr.com/5i7950 - :P
