Dead ringer 2 switch
Started by Cevin, November 04, 2014, 11:49:21 PM
Cevin
I'm about to start this build, and it looks like it's gonna be a tight fit. On tayda they now have a 2t4p rotary switch, but it looks huge. Has anybody tried this switch? Does it fit?
The only rotary switch that is going to fit in that space is exactly the one listed in the BOM. Anything else will require wiring it off-board and a larger enclosure.
Cevin
I see.... I didn't realize that the switch soldered directly to the board. I thought you wired it. That alone makes it worth the 5 bucks! Thanks for the info. I better take a second look at the documentation!
