Weener Wah is volume swelling not "wah" ing
Started by bassybeats, September 02, 2014, 06:03:39 AM
bassybeats
So just finished my Weener Wah board and used the Dunlop inductor from another wah and a Dunlop HotPotz II 500K (already had it).
It has True Bypass and the pedal passes signal but when you engage the foot pedal it only volumes swells. I realised from another post that the dunlop inductor needed some trickery to get the rights pins lined up. But it didn't change anything.
Have I wired the Hotpotz wrong or is the inductor knackered..? Any quick voltages or places to check..?
drolo
Hi,
Not sure if this is what is causing your issue, but there is a mod to turn a wah into a volume pedal by lifting the 4u7 cap (C2 on the weener wah schem). Perhaps have a look there, it might be not soldered correctly or reversed.
Check the cap, per drolo. Then if that doesn't fix it, check the inductor- you might need to rotate it. If that isn't it, check the transistor. Failing all that, you have a short or soldering error. Good luck!
