FF6.2
Started by GrindCustoms, July 18, 2014, 05:42:31 AM
GrindCustoms
Modded FuzzFactory on a Stubbii layout.
100n (C3) is on a switch with a 1uf cap.
LED clippers at the output.
6th knob is the 220K(Q1) repaced by a B250K pot, i would say that it soften the overall sound of the circuit, it instead make it easier to get the random pitch shifting/glitching/GOODNESS!!! of the FF! 8)
It's a total mess...
Built for a BYOC member. ;D
panchokunstmann
that good ideas!  I really liked it!
I have a question, I really do not know how you've added the LED clipping.
how you did it?
GrindCustoms
Quote from: panchokunstmann on July 18, 2014, 06:18:24 AM
how you did it?
Symetrical setup from output (lug2) of Volume pot, to SPDT that will lift them or bring them back to Volume ground (lug1).
Before i went at soldering it i had tried with red diffused LED and it was clipping sooner in output range, i then thought that green would look better. But their fwdV seems to be really higher... will have to swap them i guess.
Bufferz
very cool! what kind of led bezels are you using (if any - hard to tell) - they look great
affiliations: TFX
GrindCustoms
Quote from: Bufferz on July 25, 2014, 01:48:00 PM
Thanks, i use the enclosure as the bezel on most of my builts.
I'll drill the appropriate hole size for 3mm of 5mm LED and then countersunk the enclosure top.
Bufferz
Great idea, I love the look. The black paint seals the deal
affiliations: TFX
