capacitor tester trouble
Started by sgmezei, January 03, 2012, 08:01:37 PM
sgmezei
Hey folks, I purchased the capacitor testor kit from spark fun seen here:
http://www.sparkfun.com/products/9485
The build went fine but is not working. No screen no nothing. I am supposed to check  pin 7 and 20 on the chip to get 5v but I am getting 9.5v!
I checked all joints and components, and checking the voltage makes me believe I have a bad regulator (78L05).
Does this sound correct?
Josh (gtr2) has this same one so hopefully he can chime in.
slimtriggers
The trouble I had with mine was that I was using a negative ground power supply.  I switched the diode around, thinking I had installed it wrong and ended up blowing up the electro cap right after it.  :o
I replaced the cap and diode, then used a positive ground supply and it worked perfectly.
Sounds like you may have a different problem, though :-\
If it was working but now isn't it'll be part failure, it would appear the regulator has gone, but that may have caused other parts to fail as well. :(
Sounds like you need to contact the seller...
sgmezei
I was using the wrong power supply  :(
I just assumed it used a guitar style. I used a one spot. I dont think I have a "normal" adaptor even hahaha. Rat shack I guess. Will I have hurt anything or am I protected by the diode?
It hasn't worked yet. Didnt fire up first time
Thanks for the quick replies team.
sgmezei
Alright it is working fine. I tried a new adapter with positive ground and it works fine.
Thanks guys!
Excellent!  Glad you got it working.
It's a handy little tester :)
Josh
sgmezei
Yeah it should be great. Did you end up housing yours?
here's some pics for those who are not familiar
djaaz
I was thinking on a cheap & effective way to box this thing.
Even find a better socket system to plug any capacitor in there.
Anyone had a brilliant idea?
Something like this
Called a 'keyboard' enclosure, perhaps you could find one locally
CRBMoA
sgmezei
Cool, that looks sturdy. I just dont like having a raw circuit sitting on my bench next to transformers and such.
