micro spdt pcb mount switches??
Started by copachino, July 19, 2014, 02:23:47 AM
copachino
hi i hace make a layout for the lovepedal eglishman, the idea its to fit it on a 1590A enclosure with alpha 9mm pcb mount pots and also the clipping diode switch(fail on lovepedal), so i was wondering its that can be possible to do
2 layer board of 1.30x1.14 inches (35.56x28.91 mm), im not so sure if i can fit it on a 1590A enclosure, its says 2 layers but its only 1 layer pcb
switch has 0.1 inch distance pin to pin, and pot has 0.15  inch pin to pin
