Regulating 12v AC to 9v AC
Started by LaceSensor, July 15, 2014, 02:03:35 PM
Hi gang
I have a FOXROX paradox that needs 9v AC to run on.
Its so expensive and rare I am not gonna mess with it to run on DC, or try over voltaging it on 12v
Dilemma is, my PSU has a 12v AC output. I am therefore wondering how would I regulate AC down from 12 to 9v AC ?
would a 317T regulator do the job?
Any ideas / small circuit I could vero would be appreciated!
thanks
#1
edit...
ignore
Could you do a roadrage in a seperate small box (like an Altoids tin) and use it to convert the voltage?
Edit: i just found this.
RobA
I'm a bit confused. According to the Paradox website, the Foxrox needs 9VAC.
Quote
Power - Paradox requires 9 Volts, AC (9VAC) in order to operate. A power adaptor is included with each unit. Don't confuse 9VAC with 9VDC, which is what you get from a 9V battery. That's what most other effects use, but not TZF. TZF's internal circuitry runs at 36Volts DC, split into plus and minus 18 Volts. Other effects that run on 9VAC include Captain Coconut 2, Digitech Whammy, Line 6 POD, and others. The power units for these effects are all interchangeable.
Does your PS put out 12VAC or is that what's DC?
Quote from: RobA on July 15, 2014, 03:32:25 PM
Quote
power supply puts out 12vAC
I need to make that into 9vAC
Quote from: flanagan0718 on July 15, 2014, 03:28:07 PM
thats a voltage inverter, not what I need....
Do you have a Digitech XP power supply? Those are 9VAC output...  ;)
I have a suitable wall wart I just want to run it off the power supply....
RobA
Quote from: LaceSensor on July 15, 2014, 03:50:12 PM
A transformer with the right number of windings and the right VA rating. It probably wouldn't need to be a big transformer, but the little bitty guys that are designed for various DC/DC tasks won't work because their V/t ratings are way too small (I torched a couple trying it ;D).
RobA
Maybe something like this one would work,
http://www.mouser.com/ProductDetail/Hammond-Manufacturing/229A88/?qs=sGAEpiMZZMvwUzoUXIIvyQPvPmwnNFGyFPR0zXcS6jg%3d
115 to 88 is just about perfect for 12V to 9V. I don't know about the current draw of the Foxrox though. You'd need to make sure the VA rating and the current ratings on the primary and the secondaries were good. But something like it could do the job.
