does switch wiring type matter??
Started by copachino, December 13, 2014, 04:12:20 AM
copachino
hi all, im just wonddering if the type of wiring you make to the 3pdt really matter about popping issues, i have a sho and been trying to get rid of the pop by many matter i have now al electro caps nichicon and poly caps and metal film resistor, ive heard some guys never have a pop problem, but im wondering does my wiring type makes something different??
mremic01
I never have popping issues. Usually, I ground the input when the PCB is bypassed, like in the top right here:
Are you using a drop down resistor?
copachino
yes im using a 2.2M but the fx pop when its turned on, not bypass, still i have no input grounded i will try this night when i get home, or should it be better to groung the output?
