Trying to Improve my Wiring
Started by GammaFlex, May 27, 2014, 04:23:20 PM
GammaFlex
So instead of just building pedals as a whole I decided to try to take some time and improve my wiring/soldering jobs. Here's one I just finished, I've redone my layout for this pedal to eliminate jumpers/standing resistors etc...
The wiring was going to be twisted but it looked really off and didn't fit well with the twist on just one side, any thoughts? The battery sits correctly I just hadn't pushed it down in there for the picture
Rockhorst
I don't really thinks there's any problem with that wiring?it's quite neat and clean!
muddyfox
Same here. It's plenty nice.
Wiring is also highly dependent on the board you're connecting as the pads can be pretty much anywhere and your "system" may need more adjustment than you planned for.
I just try to keep an open mind and go with the flow of the build. Sometimes I hide the wires as much as possible, sometimes I let them all hang out if I can manage to do it somewhat neatly.
GermanCdn
Overall, I don't think you have a problem with your wiring, so well done.
If you're going for twisted on a vero and it looks a little off because of the location of the outs off the board, you could run your twists longer than you need, split them at the board end and cut them to the individual length required, which would allow you to run the braid down the middle as opposed to being offset.  Zip tie mounts to the enclosure also can help keep the wires in place for a pro look.
You might  want to give the solder joints on the jacks a little touchup once everythings secure, one or two of them look a little dull/cold, but if you're not noticing any problems, it's probably my eyes. ::)
Nice to see you're working on your building mechanics, it goes a long way to helping all your builds in the end.  Well done.
GammaFlex
I rechecked the joints Germancdn, all of them are solid but looking at the picture I think the outdoors light sort of washes it out and makes it look like they're cold joints.
I think I see what you guys are saying, it's more about what your layout demands rather than adhering to a "system" makes sense. Thanks for the tips/compliments guys!
That looks much better than your earlier posting.  Good job.
How is the PCB mounted?
Something you could do with a symmetrical layout like that, that will make it easier to wire, mount the pots  and switch in their holes so they are exposed outside the box, inside-out. Gives you easy access to all the solder points, easy to trim wire to length, easier to see what you're doing.
I usually create a jig/board to match the enclosure layout and do all the wiring on it except the wires to the  various jacks. Those wires are wired to the boards or switch and easily accessed and soldered once you've checked for functioning and mounted things properly inside the box.
GammaFlex
Quote from: pickdropper on May 28, 2014, 03:44:40 AM
The board is directly on top of a PCB mount pot, which in turn is directly attached to the board so it's all one solid piece.
Cool.  I didn't see a problem; I was just curious.
GammaFlex
Quote from: davent on May 28, 2014, 04:51:48 AM
That's pretty ingenious actually, I'm going to have to try that
Pickdropper, it's all good :)
