body wiring diagram for deadringer2
Started by Bluz, May 27, 2014, 06:03:32 PM
Bluz
Ok, so I ordered my parts for this build.  Bought the rotor switch from Mouser. I've read the directions through at least half dozen times. I probably over looked this but......how do I wire this to the board?  I didn't see a wiring diagram, help!......
murdog47
No wires! it mounts onto the board just like the potentiometers. It's labeled "Body"  :)
Also, the rotary only goes on one way. You'll see that the mounting clips are closer to one set of pins rather than being an even distance between them. So, when the pins and holes line up, you're set.
Bluz
Thanks,  I looked and studied this way to much!!!  Such a simple simple thing to let me get confused.....LOL!!!!!  Ignorance is bliss....... :o
