problem with grafic fuzz
Started by kost2112, May 22, 2014, 12:41:22 PM
kost2112
Hi all,
i have an issue with one of my pedals, ehx grafic fuzz, so if anyone could help me i'd be glad.
When the pedal is switched off the signal passes through normally, but when i press the button of the ehx, the signal does not pass at all although the LED is on, so i guess there is no problem with the current that makes the pedals work.
I could upload a photo of the pcb if you think it could be helpfull.
Thanks in advance.
A picture WOULD be helpful indeed.
from the info you gave us, it's nearly impossible to say something based on facts. I can only guess: it is possible that the power supply cable to the PCB is broken/solder joint ripped out. Same would be possible for the in- or output cables from the switch to the PCB.
cheers
