Sunking Bass Knob
Started by AntKnee, May 20, 2014, 02:55:21 PM
AntKnee
In addition to the treble control, is it possible to add a bass control knob to a sunking? What is the best way?
Take a look at the Sunking II schem. It shows to ways to increase the bass on the circuit. If you wanted to do it with a pot, I would put it where I did the "Fat" mod. Use a 50k pot to blend the large cap in parallel with the small cap. You could use different values to for more extreme results. Say 47n to 220n.
AntKnee
Hail Brian!
Thanks for the help. I should have mentioned that I am actually trying to do this mod to a vero layout of the Sunking I. I'm still new to the hobby, and learning to read schematics and apply them to the build. Would the mod I drew on the attached vero layout be correct, based on your suggestion?
Thanks again!
