Sharkfin No Sound - FIXXED
Started by fixxe, May 14, 2014, 01:51:47 AM
fixxe
Me again...
-I got bypass signal.
-When I touch 1 and 2 on the Board or the Connection on the Bypass switch, I can hear the ticking of the Sample and Hold.
-The Sample and Hold light is blinking and changing rate with the Speed pot
-No Voltage on Q3. Where should I look for the mistake?
-I painted the voltages on the layout. On some pins there were jumps of voltages, I guess it's got something to do with the S/H-Speed
Thanks!
fixxe
rullywowr
Did you test it outside the box?
fixxe
fixxe
Alright, changed Q3 and now it seems to work  :D
So I guess transistors and diodes should always be bought in doubles  ;D
