Madbean Wolf Shirt (Foxx Tone Machine)
Started by cajone5, January 02, 2013, 09:30:20 PM
cajone5
I built one of these a while ago for a friend (back in Sept '12) -- as requested I used a giant enclosure  ;D
I loved it so much I've been planning on making one for myself... And on the first day of the new year I finally did it.  Done up in all white  :D
Octave on/off on the toggle and the LED changes from green (w/ octave) to blue (w/o octave) depending on switch setting.
slimtriggers
That's cool!  I didn't even know they made white jacks like that.
Hangingmonkey
Real nice white sparkle enclosure.
Powdercoated?
cajone5
Thank you for the kind words folks -- BTW nice new avatar, Josh  ;)
Quote from: slimtriggers on January 02, 2013, 11:37:46 PM
Yep Cliff jacks (love using those... cuz my name is Cliff  :P ) -- I think I got them from an amp parts supplier... a quick search yielded this
http://www.amplifiedparts.com/products/S-H553
Quote from: Hangingmonkey on January 03, 2013, 12:07:54 AM
Powdercoated?
Yessir -- pedalpartsplus if I recall -- love their work
Very tidy!  Nice work putting that battery cover in... looks great 8)
bigmufffuzzwizz
I'm really digging your snow white sparkle wolf shirt! I'm curious about how you wired the LED to change with your toggle switch?
cajone5
Quote from: bigmufffuzzwizz on January 04, 2013, 01:52:35 AM
I used a DPST switch.  One side center and outside lugs are connected to the board.  Remaining lug is open.  The other side, center lug is connected to 9v power and the outside two lugs are each connected to their respective color (green and blue) anodes on the LED.
Easy as that  :D
mshuptar
Hi there - I have sort of a noob question: in the large-box version at top, how did you affix the PCB to the enclosure?
cajone5
Quote from: mshuptar on January 06, 2013, 03:25:39 AM
3m double sided foam tape
andregarcia57
today I had a problem with two pedals.
Wolfshirt + Univibe.
same vibe off the effect of this on the bottom.
used 3PDT and I made several calls en failed.
after several attempts I gave a look at some filter pedals. and decided to put 100ohms in early 9v pedal. solved!
gets the hint
Quote from: andregarcia57 on April 03, 2014, 07:22:33 PM
gets the hint
That's what ever you just said for ya! I'm glad it worked out though. Gives you a great feeling when you debug successfully.
Looks great and I like big enclosures.
Love the braids and batt door, clean!  White on white!
