Double Flush SW Pad
Started by das234, March 23, 2014, 02:25:21 PM
das234
I populated my Double Flush yesterday and I see that it has a SW pad instead of the usual + pad.  Can I still hook it up as usual to rock before I box or do I need to so something different?
Clayford
SW is to the switch for LED control. It is not needed for anything at this time. During rocking before boxing your LED will not light pulse unless you connect it ground. When you box it per the wiring diagram it will operate as intended, and not only show you the status of your pulse knob, but also on/off for the effect.
9v is in the upper right hand corner and there's an additional ground up there if you desire to run power and ground to the same place.
x  -  -
das234
Oh, duh.  I didn't even see the 9V pad when I was soldering yesterday.  Thanks.
Clayford
no worries! happens everywhere
