how do I set sweep on weener?(Solved)
Started by danwelsh, February 27, 2014, 01:31:31 PM
danwelsh
Hi guys, I have my weener working but noticed my sweep isn't all that great. How do I set this properly?...or do I need a different icar. I tested it on my dmm and it measured at 89.4k at wide open. I used an old vox one I had.
What did you use in q1?  What inductor did you use?
danwelsh
I used a 2n5088 in q1 and I used the terrible toroid for my inductor.....maybe I have to rotate the inductor do I?
Did you measure resistance across the inductor? I used the continuity setting and one set I had continuity and one set of pins I had resistance. That's the side I soldered into the circuit.
danwelsh
Quote from: jimilee on February 27, 2014, 03:26:54 PM
I did measure it jimi but I'm not sure which is continuity and which is resistance as my continuity setting is at the same setting as the 2000 ohm one on my dmm.....would I use the lower reading? and solder those 2 pins towards the circuit?
You don't have a beep when there's continuity and no beep when there's not? It's usually the diode setting.
danwelsh
#6
Quote from: jimilee on February 27, 2014, 04:00:48 PM
no. there's no beeper on my dmm....if I measure the resistance of the 2 pins going to the circuit with the pedal off....how much should it read?
Good question. What do your leads measure if you just touch them together? The wrong leads should measure the same
danwelsh
okay gimme an hour.....I'm at the docs office right now. will check when I get home....so if I touch the leads together on my dmm on the continuity setting, then on the inductor, the inductor ones that are the same shouldnt be connected to the circuit?
danwelsh
okay, i flipped it 90 degrees, and had no wah whatsoever, just volume swells, so i put it back the way it was and have wah but it seems as only half of my icar is making it wah....with my toe all the way to the floor i get nice loud wah but when i rock it back to the heel it only wahs for half way or a bit better, and when i rock it all the way back....i get no sound at all coming through....bad icar pot?
Quote from: danwelsh on February 27, 2014, 01:31:31 PM
Sorry man but......
SO MANY POSSIBILITIES WITH THIS!  ;D  ::)
Clayford
I'm assuming you've adjusted the pot on the treadle?
danwelsh
Quote from: Clayford on February 27, 2014, 06:41:32 PM
I actually just finished adjusting it......was my problem all along. ill mark this as solved. thanks for the help guys :)
