Dynacomp + Tube Screamer
Started by andregarcia57, August 12, 2014, 04:18:10 PM
andregarcia57
anyone have a PCB that would Dynacomp and tube screamer on the same PCB?
thanks
GermanCdn
Quote from: andregarcia57 on August 12, 2014, 04:18:10 PM
thanks
I'll respond to this in this thread, though you've got the same question in two.
To the best of my knowledge, I haven't seen anyone on here put out a 2 in 1 compressor/TS on the same board.  I could be wrong.
You're best bet would be to buy a board of each, and in that regard you have a lot of options.
On the Tubescreamer side
Madbean - Green Bean
Rullywowr - 8Oh8
JMK PCBS - Steaming Kettle (it's built as a hotter overdrive, but you could build it back to a stock 808)
Aion - Stratus
General Guitar Gadgets - Tubescreamer
TH Customs - Tube screamer mini (save you some space in a two in one)
Pedalparts.co.uk - Tubescreamer, little screamer, son of screamer
There's more that, but it's a good start
Compressor side
pickdropper - four knob comp, it's the Keeley circuit, which is based on the Ross circuit, which is marginally different than the Dyna circuit and can be built the same.
jmkpcbs - Engineers Thumb, a variant of the Dyna/Ross model with lower noise
General Guitar Gadgets - Dynacomp
Pedalparts.co.uk - Skwisher
Any combination of those two boards should fit into a 1590BB in a landscape layout without much problem.
You could also go the vero route as Jimilee suggested, but doing a two in one on vero is less fun than it sounds.
