I don't think I can pass on this one [major vintage GAS]
Started by Cortexturizer, January 26, 2014, 09:28:35 PM
Cortexturizer
https://www.kupujemprodajem.com/Colorsound-super-fuzz-wah-swell-10249774-oglas.htm
The price is 140 USD. The seller tells us that the pot on the wah section crackles, not on the swell section. MAybe a bit of spraying would resolve the issue. If not, now there's where I fear. What kind of mechanism is this, I can't find a good picture showing the mechanism, this is not a wah rocker mechanism, so it's not using a typical wah pot, I suppose it is using just a dual gang pot with a long shaft. Any ideas, someone seen or has one of these?
Sounds awesome! The wah kills it!
GrindCustoms
Cortexturizer
I was slow, the pedal is already marked as reserved. I can't believe it...I am literally crying.
Quote from: Cortexturizer on January 26, 2014, 09:28:35 PM
We had a crackly wah in to fix, it wasn't the pot, it turned out to be some leaky caps. Swap the caps out if the pot doesn't fix it.
