Crystal Fire
Started by aeroemi, February 12, 2014, 11:25:45 PM
aeroemi
Hi all, this is my last build... It is actually a buffer/booster pedal, I used the fatpants for booster and the Pete Cornish for the buffer stage...
So when the booster is turned off, then the buffer is activated (in the "crystal side" of the enclosure :P ) and viceversa...
I encountered (as anyone who has built the fantpants) some scratching on the fat pot when the body switch is off... Do you have any suggestion on how to remove (or at least attenuate) it? Because it's so loud that I really can't turn the fat knob while the pedal is engaged...
aeroemi
Sent from my Lumia 800 using Tapatalk
aeroemi
rullywowr
Excellent choice of circuits and nice job on the enclosure. The fat pants scratching is just part of the beast...no way of removing that noise without changing the circuit.
LJangel
cool design contrast.  looks good.  I'm not familiar with the circuit.
Love the aesthetics and the enclosure art.
mattlee0037
I believe that's normal like with a rangemaster setting the 'volume' actually set the circuit voltage so it's very prone to crackle. (Correct me if I'm wrong.)
aeroemi
Thank you all guys!! It always encourage me to go further when people like the stuff that I make... :P
hoodoo
Nice build, great graphic, perfect pair.  :)
sonarchotic
Great pedal and great name! ;D
