Panel mount trimpots?
Started by brand0nized, January 14, 2014, 07:06:36 PM
brand0nized
I can't seem to find panel mounted trim pots, like the ones used in the Mooer mini pedals..
I'm looking for trim pots that I can turn with my finger and not need a coin or a screwdriver. Preferably black, so it looks nicer :P
Anyone know where to get em?
marmaliser
rullywowr
Quote from: marmaliser on January 14, 2014, 07:32:20 PM
I think these are what you are after http://www.taydaelectronics.com/catalogsearch/result/?q=knurled+plastic
Well sort of.  These need to be mounted to a PCB and do not have a nut to secure to a panel.
marmaliser
Those are the ones moer use. The moer ones just poke through holes iirc
Quote from: marmaliser on January 14, 2014, 08:33:05 PM
Yep.
To use them, you need to devise some sort of panel with other fixed components to keep them in place.
Malekko, MI Audio, and a bunch of other manufacturers also use the exact same type of pots.
Not to blow my own trumpet, but I did something with these recently and it was really fun to devise an implementation.
You can always design them in Eagle or other CAD as a board mounted pot between other pots or board mounted switches
See here for more details: http://www.madbeanpedals.com/forum/index.php?topic=12869.msg117485#msg117485
chromesphere
Plastic shaft pcb mounted pots are a cool idea, i think the would suit controls that are less used or not as important as others (like bias, or fine tuning).  Pretty sure actually that is what mooer use them for.  I would definitely go this route if i wanted an 'external trimmer'.  Rather then...and external trimmer...
brand0nized
Perfect! Thank you! +points for finding a more common store so I don't have to do a separate order!
brand0nized
Quote from: rullywowr on January 14, 2014, 07:53:27 PM
I'm thinking to mount it with just a strip of vero, and mount that with pcb standoffs or screws to give it a steampunk-ish look on the top
