Silver Boogie
Started by pickdropper, December 22, 2013, 03:06:28 PM
Stomptown
Quote from: croquet hoop on December 22, 2013, 06:52:51 PM
Quote from: midwayfair on December 22, 2013, 06:05:25 PMhttp://www.smallbearelec.com/servlet/Detail?no=110
Those are smaller (13 mm diameter), I think those used by Pickdropper are 15 mm. They might be 45KN031 Eagle knobs, available from mouser.
They are definitely different than the ones from small bear, which I'm not really a fan of. Too tall/thin and a lot of the ones I've revieved are slightly scuffed/aged in spots. These ones look great! I'll look into the ones at mouser...
aesthetically perfect. You take the face plates to a new level.
Thanks guys.
The knobs are Eagle and most definitely were sourced from Mouser.  If anybody wants, I can look up the part number when I get home.
Stomptown
Quote from: pickdropper on December 22, 2013, 10:28:11 PM
Thanks guys.
Thanks Dave! I think croquet hoop was right but a confirmation would be cool!
Here is the data sheet from mouser:
http://www.mouser.com/catalog/catalogusd/646/2042.pdf
Lots of cool stuff on there!
Croquet Hoop nailed it.  They are 45KN031.
I have some black ones as well.  Mouser PN: 450-7031.
wretched
Hats off, sir. You are an artist.
How did you make the faceplate? It's such a beauty, I'd like to try something like that  one day
Quote from: m-Kresol on December 23, 2013, 07:27:35 AM
It is a reverse laser-etched acrylic plate.  Painted from the backside, etched backwards, then flipped and installed.
billstein
Does the laser do the outside cutting? If not, how do you get those perfectly rounded corners?
Quote from: billstein on December 23, 2013, 06:16:42 PM
Yep, the laser cut the outside as well as all of the holes for the pots, switch and LED.
I've found I have to run the etch (raster) and cut (vector) operations in the same job or things get out of alignment.  That shouldn't happen, but for some reason it does.  I haven't figured that out yet.
billstein
Quote from: pickdropper on December 23, 2013, 06:26:15 PM
Nice! I know what I want for Christmas.  ;D
