Collusalus DOA
Started by GVC66, January 04, 2014, 07:50:30 PM
GVC66
Not having any luck with flangers at all...  Here is a start for the voltage readings.  I did not complete this because something seems VERY off.  Can someone with more mxr flange experience tell if this is fubar and I should scrap it?
IC1:
1.382
.934
361.5mv
1.4mv
14.81
1.37
Varies
.82
IC2:
Decreasing
Decreasing
217mv
1.5mv
235mv
.5mv
.5mv
.5mv
IC3:
.73
0
.787
1.4mv
234.9mv
dwmorrin
Don't scrap it yet.  You need to put the pin numbers next to the voltage readings.  The only thing close to +15 I see is "14.81", but it's unclear which pin.  That would be OK for pin 8.
IC2 doesn't have any sign of power.  Should have +15 on pin 8.
IC7 and 8 supply the power to the rest of the board.  Check those.  You need to get +15 on IC8 Vo, and approx. +7.5V for "VB."
+1 for labeling the pins. Need to post properly labeled voltages for ALL of the ICs before anyone can assist.
Also, post voltages on the regulator  ;)
GVC66
My bad.  The pins are ascending order... IE
1
2
3
4
5
Etc...
I should have said something.
If that is the case then there is definitely something wrong. Should NOT have 14.8V on Pin 5 of IC1
Are you using an LT1054 for IC7? Have you double checked ALL component values and cap orientations?
Can you repost with ALL voltages for ALL ICs and the regulator?
GVC66
I just noticed I used bc549b instead of c.  I just ordered some bc549c.  Could that be it?  Should I continue to check voltages or should I wait till I replace the npns?
Quote from: GVC66 on January 19, 2014, 07:20:54 PM
I doubt it. You really should repost your source voltage and new reading at the pins of all the ICs. Make sure you properly label them!  ;)
GVC66
Ic1--
1=1.371
2=.97
3=358.7 mv
4=1.5 mv
5=.813
6=1.345
7=0
8=14.81
Ic2
1=decreasing
2=decreasing
3=215.2mv
4=1.5mv
5=descending
6=descending
7=.3mv
8=233mv
Ic3
1=.723
2=120.8mv
3=.782
4=1.5mv
5=121.2
6=.717
7=.832
8=233.6mv
Ic4
1=2.218
2=decreasing
3=2.2
4=1.5mv
5=227mv
6=12.22
7=14.14
8=14.8
Ic5
1=14.8
2-7=7.39
8=1.5mv
9-12=7.39
13=decreasing
14=increasing
15=increasing
16=decreasing
Ic6
1+2=7.39
3=14.71
4=1.3mv
5=7.39
6=1.4mv
7=1.3mv
8+9=14.8
10=10.44
11-14=14.8
Ic7
1=9.29
2=1.418
3=2.54
4=180.6mv
5=6.2mv
6=1.9mv
7=4.6
8=1.371
Ic8
1=16.57
2=decreasing
3=14.8
Ic9
1=scattered
2=7.39
3=decreasing
4=1.585
5=decreasing
6=7.39
7+8=10.02
GVC66
GVC66
I forgot to mention I am using 9volts as my source (1spot).
GVC66
Just went through this again and I am at a loss. All the parts seem to be correctly oriented and soldered cleanly.
