Python - Tap Tempo Raspberry Pi project
Started by Ettore_M, December 08, 2013, 06:47:29 PM
Ettore_M
Hey guys!
I made it!  ;D Haha! Not what you think, I didn't make a actual tap tempo as you are imagining it!  ;)
But it's a step towards the actual thing!  :)
So, I wrote some code to read two taps from a NO SPST switch with the use of the GPIOs, and change the frequency of a PWM output according to the time recorded between the two taps! And after some searching and help from the guys over at the Raspberry Pi forums, I got it working!  ;D
And it's working perfectly!
Hope you like it!
Hector
- Culturejam
kothoma
