Okay, that's really the last time I try to solder chips ...
Started by midwayfair, December 09, 2013, 02:21:49 PM
Quote from: gtr2 on December 09, 2013, 05:37:44 PMI do recommend looking into a desoldering gun for the amount of builds you do.
I've thought about it a lot*, but in this situation, I feel like it's a bandaid.
Rolly, you're right; the workshop does not have three-prong outlets. I guess I've got multiple reasons to upgrade them now.
*I would be mortified to tell you guys what I use for really drastic desoldering.
gjcamann
If you get your chips from Tayda, then you better socket!  8)
I second the desoldering gun suggestion. Mine has changed my life.  ;D
http://www.hakko.com/english/products/hakko_808.html
Regardless of your IC woes, a dedicated (quality) desoldering gun will make thing so much easier when prototyping. I don't even socket most passives anymore because I can pull one out in about 5 seconds. I can take out an IC in maybe 15 seconds, and it's clean and totally usable again.
Quote from: gjcamann on December 09, 2013, 06:11:47 PM
Only time  I've had Tayda chip troubles are when I put the damn thing in backwards  ;D
