Cherrybomb trouble ...again...
Started by VPIF, November 17, 2013, 09:00:29 PM
VPIF
Hi.
Finally got my cherrybomb to work after some frustrating debugging sessions, but it doesn't work quite as I expected. Turns out that the bass and treble controls have minimal - if any- effect on the sound, and the volume is lower than I'd expect  (unity at around Vol: 50% with Gain at 25%). I also occasionally get French radio, but this is probably due to the fact that I haven't grounded the enclosure yet. Voltages are off (see below).
Battery: 8.84V
Q1:
E: 0.38V
B: 0.93V
C: 1.92V
Q2:
E: 1.29V
B: 1.93V
C: 3.84V
Q3:
E: 0.0V
B: 1.53V
C: 8.80V
The first problem I had with this was probably due to a faulty PCB. There is 470 Ohms of resistance to ground from the emitter of Q3, as it should be, so it's not shorted to ground.
Any ideas of "suspects" is greatly appreciated
