best ways of fittin the road rage in a 1590b
Started by Gledison, November 14, 2013, 03:25:56 PM
Gledison
hey guys,
finishing my pork barrel and im wondering if i should put a road rage to board together.
It would be possible to fix the road rage on the bottom wall of the enclosure?
does anyone has other ways to optimize the mess?
cheers
Use low profile parts and it'll (just) fit underneath
Gledison
Quote from: juansolo on November 14, 2013, 06:38:42 PM
Geezz! Too late man! I have only this long caps! :(
GermanCdn
If your got room behind the switch, you can mount it vertically on the enclosure wall with some double stick foam tape.
Gledison
Quote from: GermanCdn on November 14, 2013, 08:57:57 PM
yes, Curtis, that was I was thinking about. I didn't etch the board yet and wasn't sure if would fit...
this will save a lot of space..
thanks
Check out the madbean build doc for the Quadrovibe since it shows a Roadrage in a 1590B from what I can tell.
If you run out of low profile parts, there's always other options
So THAT'S how you do those impressive 1590A builds! ;)
Quote from: alanp on November 16, 2013, 04:15:25 AM
Yep.  It's been a smashing success.   :-)
Gledison
Quote from: pickdropper on November 16, 2013, 03:27:35 AM
Ehehhe! Very important tool! The have it  on smallbear?;)
Thomas_H
you can also use a CNC mill to make low profile circuits. Just solder them completely then use the mill to make it every height you need :-)
DIY-PCBs and projects:
Gledison
Quote from: selfdestroyer on November 16, 2013, 02:02:22 AM
hey man! that is how I would like to do it! thanks for the tip!
cheers
Gledison
