Zero Point SDX IC5/LFO
Started by fastluck, November 10, 2013, 04:24:51 AM
fastluck
In the Zero Point SDX, IC5 is marked as a TL062 in the build docs...will a TL072 work here instead?
joe
Should do, it's amazing what you can get away with for substitutions.
IIRC, the pinout is identical, so it's worth a shot :)
Yes, it will work fine. TL062 is the low current consumption version of the TL072, but either will do the job.
fastluck
