Mounting pedals to a board
Started by billstein, October 24, 2013, 12:57:03 AM
billstein
icecycle66
I've done it.
If you don't move your pedals around much it's really nice and secure.
It you do move your pedals around then it's a big pain.
hylandren
Hm...the only problem is if you want to change out pedals.
What if you still screw the bicycle chain link to the bottom of the pedal, but have the material that the pedals sit on be something perforated, with lots of holes. Instead of screwing/bolting the chain link to the pedalboard, you could Just pop rivet the chain link to the board.Then if you want to change something out, cut the aluminum pop rivet, relocate the pedal and pop rivet it again. Just a thought.
Quote from: hylandren on October 24, 2013, 01:54:36 AM
I think that falls under the,"it's a big pain" part
