Zero Point DD Clipping Issue
Started by Bantha Fodder, August 28, 2013, 12:11:16 AM
Bantha Fodder
Hey boys! I just finished up one of the fine Zero Point DD's and everything seems to be working as it should. Trouble is when I plug in my double humbucker tele I get some pretty noticeable clipping on the delay. I was just wondering if this is a common problem, and if so if any of you brains out there found a way to make this guy a little more humbucker friendly.
I can post the guts n all, but I figure this is more likely just due to some component value or whatnot.
Bantha Fodder
Lonesome bump
I'm still having the clipping issue, not sure if its because of the clamp diodes or some resistor value I could change. Any help would be very welcome.
