TL072 instead of TL062 for the PorkBarrel
Started by Gledison, October 18, 2013, 05:08:39 PM
Gledison
Dear experts.
need ur help again..
I was checking the Datasheet of both ICs and it says that the TL062 is a low power but the TL072 is a low Noise IC. I have an extra TL072 and I would like to ask you guys if it would be ok..
thanks a lot!
croquet hoop
Gledison
Quote from: croquet hoop on October 18, 2013, 05:25:26 PM
http://www.madbeanpedals.com/forum/index.php?topic=867.msg5480#msg5480
Looks like it's ok. Socket it if you want to be able to swap it later.
thanks mate. I've searched first but could find anything..... ooops
RobA
It should work, but the low power versions seem to help with ticking from oscillators. I think the original called for a TL022. Socketing it would be a good idea in case you do have issues with ticking/thumping.
DutchMF
Yup, the original had a TL022, I have 2 scavenged from other pedals, but they make no decernible difference to the TL062. I think a 72 will be fine.
Paul
Gledison
thanks,
i will socket it and see how it goes!
cheer guys
As long as you remember that some circuits can be very picky, it's amazing what you can get away with sometimes for substitutes.
DutchMF
Quote from: Gledison on October 18, 2013, 07:26:55 PM
thanks,
cheer guys
That is without a doubt the best thing you can do!
QuoteAs long as you remember that some circuits can be very picky, it's amazing what you can get away with sometimes for substitutes.
And alanp's advice is also a good thing to keep in mind..... Experiment!!
Paul
